6571Views3Replies
Author Options:
How do I connect a twisted copper lead to a carbon brush motor? Can it be soldered? Answered
The tiny wire connected to the carbon brush on my palm sander broke off right at the carbon brush. Is this solder-able? The 3/8" bit of wire is connected to a blade connector on one end and used to be connected to a small depression on the side of the brush. Thanks for any advice.
Jack A Lopez
Jack A Lopez
Best Answer 10 years ago
Maybe this is solder-able?  Solder sticks well to to copper, brass, and sometimes other shiny metal.  It won't bond directly to the carbon/graphite brush, so I'm hoping that there's still a little "nub" of metal sticking out of that part.
A nice thing about the carbon/graphite brush itself is that heat won't damage or melt it.  You can heat it up as much as you want in your soldering attempt.
aeray
aeray
Answer 10 years ago
That's the problem: there is no nub left that I can see, just a slight depression.
Jack A Lopez
Jack A Lopez
Answer 10 years ago
If there's no metal left in the brush, then there's nothing to solder to, and soldering won't work.
I don't know.  Maybe there's a way to load the thing back into its housing so everything is touching and held in place with just spring-forces?
Otherwise it may be time for a new brush.
