6546Views4Replies
Author Options:
How do I convert a weed eater to edger? Answered
I have a Poulan Pro (PP133) gas trimmer and I would like to convert it to an edger. I am also going to try and find a way to install or convert it so when I hit the head on the ground the string will advance instead of having to turn off the weed eater to install new string. Last time I called the Home Depot they sell an attachment that does edging for my weed eater but it cost over $79. It almost costs more then my weed eater. Thanks. AL.
mpilchfamily
mpilchfamily
8 years ago
If you want to use the weed eater as an edger then turn it on it's side. Nothing more to it unless you want to attach a wheel to the side so you can more easily walk it along the edge of the path/drive. There is no need for an edger attachment when the strings can do the same job.
alsports2000
alsports2000
Answer 8 years ago
Thanks for your answer but when I try that the string does not reach all the way down the driveway. When we pay a lawn guy to mow our lawn he uses an edger and the yard look very nice. I am definitely going to look into installing a wheel though. Thanks again. AL.
rickharris
rickharris
8 years ago
Copy the attachment - Without seeing what you have it's almost impossible to advise further.
The string feed is a function of the cartridge. So you either need to get one that fits or look at one and copy the mechanism.
alsports2000
alsports2000
Answer 8 years ago
Thank you so much for taking the time to respond. I will follow your suggestions. Thanks again. AL.
