2497Views32Replies
Author Options:
How do I determine the primary turns needed for this PLL solid state Tesla coil? Answered
I have nearly completed my SSTC but I am unsure how many primary turns are needed, is it just an educated guess, or is it calculated?
There are no specifics on this on the website http://uzzors2k.4hv.org/index.php?page=pllsstc1.
iceng
iceng
Best Answer 9 years ago
This site gives turn info for primary = 20 and secondary = 1500...
And I fixed his pin 7 to pin 8 for you. . . . . . . . .  A
The MadScientist
The MadScientist
Answer 9 years ago
The primary turns seem to vary between different coils but I can't figure out exactly why.
iceng
iceng
Answer 9 years ago
Steve C is a knock out designer always adjusting his Tesla.
May I suggest you wind the most primary turns you know of,
because it's a lot easier to unwind a few turns then to add Some !
A
The MadScientist
The MadScientist
Answer 9 years ago
What would happen if I cut the MOSFET drivers out of the circuit?
iceng
iceng
Answer 9 years ago
The mosfets wouldn't turn on either circuit
The 1:1:1 are gate drive isolating pulse coils ( Xfmrs )
The MadScientist
The MadScientist
Answer 9 years ago
Would I be able to power the circuit off 5A?
(I blow up one of the MOSFET drivers due to a circuit error)
iceng
iceng
Answer 9 years ago
Make sure you vid it for us.
A
The MadScientist
The MadScientist
Answer 9 years ago
One last thing could you drive the GDT with Darlington transistors? (a circuit of mine I'm thinking of building, different SSTC)
Thanks.
iceng
iceng
Answer 9 years ago
Sorry you can not.
A darlington is a current driven base-emitter ( mili watt ) to turn on main current.
As opposed to a MOSFET which is a small voltage driven gate-source
( micro watt ) to turn on main current.
The pulse xfmr and circuit is sized for driving voltage gstes only.
A
The MadScientist
The MadScientist
Answer 9 years ago
Then would it be possible to make up a circuit that will discharge a capacitor into the GDT to drive it?
iceng
iceng
Answer 9 years ago
The 470 nF capacitor in series with 5 ohm resistor in your example and
the o.33 cap in my example are both circuits that discharge a capacitor
into the GDT to drive it !
A
The MadScientist
The MadScientist
Answer 9 years ago
So would this circuit work?
The transistors are driven off a 250kHz alternating signal (I know I wrote 150kHz) while the capacitors are being charged by a 12V source.
Dual primary GDT 1:1:1:1.
iceng
iceng
Answer 9 years ago
Some problems with both sides
I'm going to be at Burning Man all week, no web no phone :-D
iceng
iceng
Answer 9 years ago
Why turn on mosfets in series first One Then the other. . . . . . A
The MadScientist
The MadScientist
Answer 9 years ago
That part of the circuit would be the same as the PLL SSTC circuit.
iceng
iceng
Answer 9 years ago
OK the primary should work. The secondary outputs need that 15VZ
for limiting the V-gate and shunting as a diode to near zero volts
negative to gate While the other gate is turned on..
The common core actively fires one gate while reverse bias the other.
The diode gives -0.5 volt instead of -12 Volts.
A
The MadScientist
The MadScientist
Answer 9 years ago
So you're suggesting that I shouldn't have the reversed polarity on the MOSFET gate while the other MOSFET is turned on?
iceng
iceng
Answer 9 years ago
Yes use the Zener as I show to protect the Gate from over voltage and under
voltage.. Negative drive guaranteed zero is enough and -o.5V is enough is fine..
A
The MadScientist
The MadScientist
Answer 9 years ago
I will be using IRFP460's they have a gate to source voltage of 20V max, will the zeners be necessary?
iceng
iceng
Answer 9 years ago
What is GDT please.
Grengate
Grengate
Answer 9 years ago
Those are available . 199 or 300 turns.
A
The MadScientist
The MadScientist
Answer 9 years ago
GDT's generally only have about 10-12 turns.
iceng
iceng
Answer 9 years ago
Silly me, GDT <==> Gate Drive Transformer LoL.
Probably works ( 12T ) for MOSFET gates.
Long ago, in SCR and Triac applications we used more turns
because these devices fire on a current pulse with some duration
in case the pulse occurs at AC line zero crossing.
A
iceng
iceng
Answer 9 years ago
100 or 200 turnss
The MadScientist
The MadScientist
Answer 9 years ago
The MadScientist
The MadScientist
Answer 9 years ago
I've built a coil with 26 turns I'll play with that and hope the MOSFET's don't blow.
Thanks!
steveastrouk
steveastrouk
9 years ago
It can be calculated, but its usually made then measured. Measuring in the position you have it is very difficult. You need to watch the coil current waveform.
Steve
The MadScientist
The MadScientist
Answer 9 years ago
Will it still work if you don't do this and just have maximum amount of turns before over coupling?
steveastrouk
steveastrouk
Answer 9 years ago
No, because you will saturate the core and blow your IRFP450s
The MadScientist
The MadScientist
Answer 9 years ago
I thought the core would have a high chance of saturating with less turns?
