296Views5Replies
Author Options:
How do I enlarge a picture to a door size from an 8x10 size How do I make a door size picture from an 8x10? Answered
I am redoing my sliding glass doors. I use Gallery Glass paint to make images on them
liquidhandwash
3 years ago
Have a look at this
https://www.instructables.com/id/Giant-Poster/
Downunder35m
3 years ago
A Pantograph (purpose made for the door size) would also work great.
Depending on the details it might even be faster.
Apart from that I would prefer a cheap projector, these old ones for the tiny sliding images are great.
But it takes either a good printer to make a tiny pic on transparent foil or a little bit of modifications so the rojector accepts bigger images.
rickharris
3 years ago
A very basic way to scale things is to draw a grid over the original. Copy this grid but at a larger or smaller size. then copy the drawing square by square onto the new grid.
This sounds a long process but isn't actually all that bad.
You can make a reasonable copy even if you are not artistic.
In the image i have copied the celtic know at twice the scale of the original.
Original grid 10mm copy grid 20 mm.
rickharrisrickharris
Answer 3 years ago
I should add that you can put the grid onto an acetate sheet or tracing paper and then over the original so you don't need to draw on your original art.
