1412Views9Replies
Author Options:
How do I fix my tesla coil? Answered
My tesla isn't working, and I just want to see if anyone sees a problem.
* NST voltage: 10,000 Volts 30 mA
* 12 AWG connections wire (radio shack)
* 15 feet primary copper tubing
* 900 feet secondary winding
* Aluminum ducking top load (18 inch diameter)
* 12 0.22 uF 2000 volt capacitors (total: 12,000  volts, 0.0073 uF)
* 2mm spacing spark gap
* ground rod: metal knitting needle
If you need more information, just ask (pictures below).
Thanks for your help! (I need it to work in half a month)
Mr. Apol
Mr. Apol
Best Answer 11 years ago
If that black object is your transformer, I am pretty sure it is a modern unit with GFI (ground fault interrupt). This will not work in a Tesla coil circuit, as it is designed to not allow arcing; this is a safety measure for its intended use as a sign power source. Old fashioned NSTs are much larger, heavier devices without GFI.
The fault lies in your choice of transformer.
steveastrouk
steveastrouk
11 years ago
Try and check for a shorted turn on the secondary (sorry)
Comhippy
Comhippy
Answer 11 years ago
I don't think it's the secondary because the spark gap isn't sparking at all on the primary circuit, and when I measured the voltage the capacitors are storing, it came to be between 100-1000 (sometimes it's low, and sometimes it's high)
steveastrouk
steveastrouk
Answer 11 years ago
A shorted turn would have that effect, because the load would be reflected into the primary of the transformer.
Comhippy
Comhippy
Answer 11 years ago
I don't think mine can because it has an insulator which prevents it from shorting. I'm pretty sure the primary suspect is the capacitors because they can only charge to a 1000 volts when they should be charging to more.
steveastrouk
steveastrouk
Answer 11 years ago
How are you measuring the voltage ? You'll need a high voltage divider to read 10kV.
Comhippy
Comhippy
Answer 11 years ago
Yeah, but it turns out the voltage it IS generating is under 1 KV. I think the capacitors aren't charging enough.
steveastrouk
steveastrouk
11 years ago
HAS it worked, or is this new ?
Steve
Comhippy
Comhippy
Answer 11 years ago
no, it hasn't worked ye, and it's new. The spark gap isn't sparking, but when I disconnect it from the primary, it sparks across.
