424Views6Replies
Author Options:
How do I go about making a Lutron 120vac 60hz household dimmer light switch capable to use for 12vdc?? Answered
I want to use this switch for examle in my car connect by the accessory or cigarette lighter plug and it will run a 12vdc fan motor i can control cfm/speed.
orksecurity
orksecurity
9 years ago
Can't be done. Use a motor control circuit designed for 12VDC. That'll probably be cheaper too.
orksecurity
orksecurity
Answer 9 years ago
(Well, it can be done if you invert the 12VDC up to 120VAC, put it thru the dimmer, then use a transformer and rectifier and filter to convert the output AC back down to DC. But trust me, you don't want to go there.)
Zerocool818
Zerocool818
Answer 9 years ago
that will waste way too much power in the form of heat
orksecurity
orksecurity
Answer 9 years ago
Like I said: You don't want to go there.
steveastrouk
steveastrouk
9 years ago
Won't work, because they need AC supply to operate, since they use a triac which won't turn off unless the voltage across it drops to zero ( I simplify slightly)
As Ork says, this won't work
Steve
