5117Views5Replies
Author Options:
How do I make a batch file that will open a file from a flash drive (i.e., with a changing drive letter)? Answered
I use PortableApps on my flash drive, and it displays an icon in the menu if there is an application in the PortableApps/whatever directory. Two programs that work off a flashdrive, though not optimized for portable use, are Inkscape and Eagle. Both programs, however, have numerous applications in their main directories, which all appear.
What I'm after is a batch file that I can compile to .exe that will open the main program applications. I know that I can just put START C:/directory/application.exe to open an application from a known location, but my flash drive might be anything from E: to L:, depending on where it's used. Is there a command or code that will open a file from the same drive that the batch file is in, regardless of the drive letter?
orksecurity
orksecurity
11 years ago
Or write the batch file to search drive letters, in sequence, for a file which you know will only exist on that drive (such as the executable).
iBurn
iBurn
11 years ago
 SOMETHING I KNOW ABOUT!!! :D
Just don't include the drive letter, because if you're running it from the flash drive it should automatically have the drive letter as its root. Hence, if you were trying to open a file called [inkscape.exe] from your flash drive which we will assume is [F:\], and it was located in a folder called [portapps], you would just type the following;
start portapps\inkscape.exe
exit
TA DA! That should work. If not you could always use a shortcut, but whatever.
g-one
g-one
11 years ago
You can use 2 opportunities.
1st Use a relative path (without the drive letter):
start "" "\somewhere\app.exe"
2nd Use the absolute path (the drive letter of your batch path find in %~d0)
start "" "%~d0\somewhere\app.exe"
NachoMahma
NachoMahma
11 years ago
.  IIRC, START <filename.ext> (no drive letter, dir name, nor leading slash) will look in the current directory.
lemonie
lemonie
11 years ago
To complicated, too silly. Fix the drive letter on the flashdrive instead. Batch script is like BASIC - limited, and few people write it for anything serious.
L
