313Views4Replies
Author Options:
How do I make a long nozzle for a silly string can? Answered
I had an Idea for a Silly String firing Dalek Gun. Anyone have any ideas on how
to rig a long nozzle to reach the end of the Dalek gun barrel?
BryanD101
BryanD101
1 year ago
Has anyone mastered this because I open to create a festival totem in which discharges multiple streams at a time.
iceng
iceng
3 years ago
The pressure release has to be moved to the left most tip .
Otherwise it will clog the firstime.
elkaddalek
elkaddalek
Answer 3 years ago
(THINKING) - I'm wondering, is there a way to adapt the can, or use a thin tube like a coffee stirrer or a tube you find on those WD40 oil cans. Is there a long enough tube the thickness of a oil can tube you can buy? Ive seen a video where you can make actuate recipe silly string.
--- I do plan to make a tube running from the can to the tip of the barrel. Is just how, that stumps me. What tube to use, where can I find that size tube. Will it jam in the small tube? Will making a container with a recipe silly string & custom valve be nedded?
JeffreyArts
JeffreyArts
Answer 3 years ago
Have you already tried using one of those WD40 tubes? To see if that works. If so, do you have a video so we can see what happens?
rickharris
rickharris
3 years ago
It depends on your equipment. If you had access to a lathe you could turn an adaptor for any size tube.
If not you limited to either buying or finding a suitable sized tube (no idea where) or making the hole in the existing nozzle big enough fir what tube you can find.
n the other hand you could make your own pressure vessel with a long nozzle and vent the silly string into that vessel, Silly idea I know.
