481Views1Replies
Author Options:
How do I make an ariel for a TV? Answered
Tags:tv
11010010110
11010010110
Best Answer 11 years ago
cut 2 pieces of up to few mm thick metallic cable or pipe. each should be in length 1/4 the wave length of the station you want to recieve
connect them to 1 stick 1/2 the wavelength but so they won't be in electrical contact
connect a wire to each in the place where they meet each other
get the wires in parallel (maybe a bit twisted together) to the 2 screws on the tv
if your tv has coax input then try to connect 1 to the center and 1 to the shield. that does not allways work well. it may be better to use a converter plug frm 2 screws to coax
hold the antenna thru an isolator and play with its location and aiming
a sight and reflector may sometimes help :
cut 2 more pieces of that wire or pipe. one about 20 mm longer and one 20 mm shorter than the stick you allready have
arrange all 3 like III with proportions such that they form a square and the actual antenna is the center one
use isolating materials to hold them like that
aim with the shorter one to where the broadcast comes from or big concrete walls which may reflect the broadcast. if 1 is the shortest one then it should be
III <---- ( ( ( broadcast
321
