2309Views5Replies
How do I make an elastic powered vehicle which will transport and egg 2 metres up a ramp with a 35 degree angle?
Basically, we must use an elastic band and there is no catapult allowed. The ramp is very steep and we can't use batteries or anything. We were thinking something to do with weights. Please help! We tried knex, but it ended up being too light. And it needs to go against gravity!
11 years ago
go to toyota and buy a 3rd or 5th hand car
11 years ago
A small barrel or drum (like a coffee tin).
Stretch the band from end to end inside the drum.
Suspend the egg from the middle of the band so that it sags down.
Roll the drum three or four metres backwards, then release.
Answer 11 years ago
this is similiar to the "funny barrel" or whatever the classic kids toy is called. I think using that idea for this application is a Great idea! simple, cheap, effective. just be careful, make an egg harness so you dont break it.
11 years ago
put a spike (i used a tan lock from knex) on the rear axle wrap the rubber band around it then attatch it to a fixed point. so when you pull the car back the rubber band gets wound up and when you let go the car goes forward.
11 years ago
Make a 2 meter tall vehicle that falls over? Put a brick in your knex vehicle to add weight? Big wheels with the band on the axle? The Barometer way...(offer payment of an elastic band to place the egg at the top of the ramp)
