168Views5Replies
How do I make (not buy) an IR reciever and Transmitter that can turn a machine on/off and 3 other options.
How do I make (not buy) an IR reciever and Transmitter that can turn a machine on/off and 3 other options. The simpler and smaller the better.? It must be IR.
I want to turn a machine on/off, move a motor up, down, and rotate.
Best Answer 7 years ago
I assume you mean assemble components. Well this would be easier to do with a microcontroller like an arduino to which you could connect your receiver along with a relay, so that when your receiver detects a signal from your transmitter circuit (could be any remote control, or just an IR led and a battery) it closes the relay. If your not happy using a microcontroller then that might get a bit tricky. Hope it helps. For a basic guide on that sort of thing with an arduino check this out.
Answer 7 years ago
See Response below for additional Info
7 years ago
What do you actually mean by "Make" buy the components and assemble or actually make them?
Answer 7 years ago
Alot of responses to this type of question during my research to others Q&A is to buy one...but I feel that defeats the purpose of building something to do what you want. I want to build the remote & The reciever, i am thinking Arduino is going to be the way to go.
Answer 7 years ago
It may depend on what your programing capability is (C)
The Picaxe family will do IR control with any sony code handset as native instructions making things a lot easier.
www.picaxe.com.
