86Views6Replies
Author Options:
How do I neatly open a soda can? Answered
I have tried with a can opener, but it leaves really rigid edges which are sharp, crooked, and dangerous.
Jack A Lopez
Jack A Lopez
4 years ago
There is a particular style of can opener I have found works well for this. I am not sure of the most recognized name for this style of can opener. I think it is called "camping", "GI", or "P38", can opener. It is a very small, compact, can opener, intended for camping, travel, or for fleeing your homeland as a refugee, which is kind of like camping I suppose...
Anyway, I took some pictures of this style can opener being used to cut the top out of an aluminum beverage can, here:
https://www.instructables.com/file/FRFMRD7GB0JQNFT/
https://www.instructables.com/file/FXUJ2R5GAPV8EDX/
https://www.instructables.com/file/F25HCQ2GAPV8EDY/
rickharris
rickharris
4 years ago
A pair of normal household scissors do a good job. if you want to avoid the sharp edge fold it over and press down hard.
bwrussell
bwrussell
4 years ago
THIS method should work as long as you're careful to not crush the can.
iceng
iceng
4 years ago
Pull the tab.
Downunder35m
Downunder35m
Answer 4 years ago
That would be too obvious don't you think?
iceng
iceng
Answer 4 years ago
Yes ;-)
Years ago when we wanted alcohol in a state park, Someone would drill a tiny hole 1/16 " in dia at the bottom of a 7-UP can, then we would let some soda out and squirt 20 cc of Seagram Seven whiskey to form the 7*7 cocktail and
neatly solder seal the hole closed.
No search of our coolers ever had a hint of the ruse !!
Yes the soda cans were easy to solder because we did not solder aluminum !
