11506Views7Replies
Author Options:
How do I paint plastic containers, and then protect the surface? Answered
Plastic containers like milk containers, for example.
Mindless Wolf
Mindless Wolf
8 years ago
To protect paint from being scratched off from daily use, you can use a mix of wood glue and water. I use a 50/50 mix for general applications but u can go thicker on the glue as you see fit. A 70/30 mix of glue to water gives a nice protection and dries faster than 50/50 but you might lose some detail if there is any on the surface you want to protect.
The Lightning Stalker
11 years ago
Make sure it's very clean before painting. Clean it with some denatured alcohol to remove any skin oils, etc. Just make sure nothing can touch/dent it after it's painted. If you rough it up to get the paint to stick better, clean off all the particles made during the process, or else they prevent the paint from making complete contact.
jtobako
jtobako
11 years ago
There is a Krylon brand paint for plastics, but it takes about a month to mostly bond to the plastic (it still scratches off, but not in big pieces).
seandogue
seandogue
11 years ago
If you're doing it on the cheap, you can spray them with a couple of coats of clear acrylic after the color coat(s), but re-design's suggestion will be more durable in the long term.
seandogue
seandogue
Answer 11 years ago
Clear acrylic OR clear polyurethane...
Re-design
Re-design
11 years ago
You can paint them using automobile paint. YOu have to add a plasticizer to make the paint flexible. It's what they use to paint plastic car bumpers and fenders. You probably need to scuff up the surface before you paint so it will stick.
Re-design
Re-design
Answer 11 years ago
You might be able to buy this kind of paint in spray cans sold as touch-up paint.
