539Views2Replies
Author Options:
How do I roast edamame? Answered
I'd like to roast edamame in my toaster oven using little or no fat and little salt.
Tags:vegan
ironsmiter
9 years ago
You want a roasted nut in the end?
edamame, as Re-design pointed out, is a boiled and salted preperation of soybeans. Usually not-fully matured beans.
You could TRY a recipe an arts-director I knew used to make.
Take normal, fresh peas(not in the pod). Frozen has worked OK, but just not as good as fresh. Soak them overnight in a brine solution(aka salty water).
Drain and rinse(all the salt you want is already inside the pea now :-).
Toss the peas in a bowl, with a tablespoon or two of olive oil.
Preheat the oven to 450F.
Spread the peas out on a cookie sheet, one layer thick. a little moe room is better than tightly packed.
Bake for 30-40 min.
Good wen hot OR room temp as a snack.
Also works well for chick-peas, which is why I think soynuts should work too.
Finally, I like mine a little spicy, so while still hot, I sprinkle on a little cayenne pepper and toss.
Re-design
10 years ago
I thought it was boiled.
