3377Views3Replies
Author Options:
How do I take the air restrictor out of a Nerf Deploy CS-6? Answered
Tags:nerf
orksecurity
orksecurity
10 years ago
Are you sure there is one, as opposed to there simply being a sufficiently narrow tube/channel to achieve the same effect?
Blackonyx2234
Blackonyx2234
Answer 10 years ago
The long and narrow tube will actually increase the pressure while the air restrictors spread the pressure out to dampen the speed.
thiskid
thiskid
Answer 10 years ago
You should be able to see all the way through the barrel when you remove the air restrictor right?
dskissel
dskissel
Answer 9 years ago
Yes, it depends on how you remove the air restrictor. I drill it out with a 3/8 drill bit., so I can usually see through to the plunger.
