25361Views7Replies
How do I transfer music from my iPod to a new computer, without losing the music I have?
I would like to transfer music from my iPod to a new computer, without losing the music I have on the iPod as well as the music that is already on the new computer. My old computer crashed, and my music is only on the iPod. I've already uploaded and purchased music on the new computer, that wasn't on my iPod before. I'm afraid to hook the two together, because I've heard you can loose music. Any ideas on what I can do?
3 years ago
Add music to the iPod with a new PC without losing your old content…Click here to know more www.officialtechsupport.com/how-to-add-music-ipod-without-deleting-old-one
4 years ago
To transfer music from iPod to computer without data losing, you can make it with the help of a third-party program. And I think iPhone Transfer, which is a good transferring tool to transfer files from iTunes/computer, will be a good choice for you. By the way, iTunes is another option for you too.
Read more:
https://www.recovery-android.com/ipod-to-computer/...
5 years ago
How to transfer music from iPod to computer? You can use iTunes to do it .Confirm that your iPod is configured to enable disk use. With Enable Disk Use this function, you can easily transfer music from iPod to computer. See following guidance:
1.Install iTunes on your computer .
2.Connect your iPod to computer via USB cable and launch iTunes
3.Find "Options" and check "Enable Disk Use".
4.Open "My Computer", and double click "My iPod" to open it.
5. Click "Tools" in the toolbar. And then click "Folders > View" and tick "Show hidden folders and files".
6.Open "My iPod > iPod_Control" and then you will see all the iPod music in that folder. Select the music ,transfer and copy music to computer.
5 years ago
Hey, simply try this phone music manager, which facilitates you to transfer music from idevices to PC without iTunes.
http://www.apowersoft.com/phone-manager
5 years ago
You can transfer your iTunes store purchases directly from
your iPod as detailed here
http://support.apple.com/kb/HT2519
For the rest of your music, such as songs you ripped from
CDs, you will need to use third party software such as TouchCopy.
http://www.wideanglesoftware.com/touchcopy/
I had it recommended to me on Apple support communities
here, worth checking this article out...
https://discussions.apple.com/docs/DOC-3141
5 years ago
If you are looking for the tool on How to Transfer Music from iPod to Computer. I think you should definitely try iPod Transfer.
11 years ago
Im doing this by memory so some of the exact names of the menu may not be accurate but the general idea will get you there.
Try using WINAMP (v 5.x or higher):
1.- Install Winamp
2.- Connect your Ipod and close ITunes if it comes up.
3.- Once installed, Right click it and select Music Library.
There is a PORTABLES section in the left menu on the Music Library where you should see your Ipod, Expand It and select Audio/Music option
4.-In the right side of the screen you should see all you music. Just Select all and right click it and the select Move To > Local Drive.
5.- You can find all the music you selected in "My Documents/My Music" Folder (Windows only)
11 years ago
also your welcome and jeff thats the easy way
11 years ago
Here's a way to quickly get files off a PC iPod without any extra software.
Read more: http://www.methodshop.com/gadgets/ipodsupport/copyoff/index.shtml#ixzz0WNnBkpJP
11 years ago
Before hooking up the iPod, make sure you have iTunes set to "manually manage music." This will prevent it from automatically loading new stuff, and deleting what's already there. To copy the music from your iPod to the computer you'll need a special program. There are probably dozens of them out there, do a search at download.com and get the highest-rated one.
