107Views9Replies
How do I transform some kind of voltage into 5v?
I'm planning on building a circuit with an ic which needs 5 volts, and I don't want to use a computer as a powersource, what can I do?
Or can I use 4,5 volts for it.
Thanks,
BoK
Thanks,
BoK
Best Answer 9 years ago
I do 328s all the time at 4.5v
Ive also tried 3v, it doesnt work on mine (probably I havn't changed fuses/bits/whatever)
5v is the "stable" configuration. If youre project relies an precise timing, its better to do it with a regulator :)
Answer 9 years ago
Hmm, read the Atmel datasheet. Its rated from 1.8 to 5.5V, and works reliably. If your project needs precise timing, you need to use a crystal.
Answer 9 years ago
of course. *Duh. Forehead slap*
9 years ago
Transform suggests a 5volt wall wart..
A
9 years ago
A 328 will work fine on 4.5 Volts. It will work from 1.8 V to 5.5V.
LDO ? Look it up.
Steve
Answer 9 years ago
there ya go, now did the author consider asking the voltage very politely if it would be lower?
9 years ago
I'm using an atmega328, and what is best 4.5 or 6 volts, what does LDO stand for? ;D
Answer 9 years ago
low drop out
Definitely look at the datasheet. A regular regulator has a 2 volt dropout so you really want 7 volts in to make stable 5. A LDO regulator will have as little as a quarter volt drop. meaning you can reasonably supply 5.5 volts for a stable supple.
You'd really want bare minimum 4x1.5v batteries to get 6v for stable operation on a 5v chip.
9 years ago
Depends on the chip. It might work on 4.5 volts, otherwise, use 6V and a small LDO regulator
