3525Views15Replies
How do I use a PIR (Passive infrared sensor) motion sensor to turn on a 3v battery?
Hi All,
I want to use a PIR to turn on a small 3v DC motor. I know that I can't just directly attach the motor to the PIR as there isn't enough power to run the motor. I have done some research and it looks like I could use a 3.3V relay as a switch to drive the higher power needed for the motor
what I want to know is how to wire it all up? Do I have to supply a separate power source to the relay to run the motor? If anyone has a schematic that would be great. I found this relay on ebay which I thought might work but I'd like to make one myself if possible.
thanks for your help.
lonesoulsurfer
8 years ago
Here is a two voltage relay that is controlled by a PIR detector.
A
Answer 8 years ago
Thanks so much iceng. Makes perfect sense.
Can you recommend a relay to use? I really only want to use 4.5v to trigger the PIR so the relay would need to trigger at around 3.3v, the same as the PIR.
Answer 8 years ago
Try this 5V coil relay from parallax for $2.75 see the spec.
A
Answer 8 years ago
Will a 5v relay work ok even if the voltage trigger from the PIR is only 3.3v?
Answer 8 years ago
Might not work, i found this 4.5 VDC unit.with different pinout
maybe you can find a lower voltage ////
How do you make a 3.3 v supply. ?
Or show the PIR schematic so I can engineer a transistor instead..
Answer 8 years ago
Hi Iceng, What about this relay I found on ebay - it triggers at 3V - would this work? Sorry - I couldn't find a schematic of the PIR sensor that I have. It's one I brought from Ebay and are very common.
Answer 8 years ago
The power supply to the PIR can be anything from 3.5v to up to 12v. it will give out 3.3V (on) once it detects heat for a period of time then drop down to a low voltage (off) state once it has finished.
Answer 8 years ago
Try it on 6V and 12V with a voltmeter on the PIR output
to see if it only delivers 3.3v in both cases ??
Answer 8 years ago
Yep - tried that already. It always delivers 3.3v. The PIR has a little voltage regulator on it.
Answer 8 years ago
Looking at the eBay relay and this thread.
YES ... they will all work together.
Run the PIR and relay on 4.5V ( 3 AA in series )
Run the motor and contacts on 3.0V ( 2 AA in series )
A
Answer 8 years ago
Thanks for all your help. Really appreciate it!
Answer 8 years ago
how much power does the motor take? Just use a transistor and a diode or two to drop the voltage for the motor.
Answer 8 years ago
I've seen that relay before....
Answer 8 years ago
good visual memory :-))
Answer 8 years ago
Thanks.
