How do I use an Arduino to write say 2.1 volts? Hobo dataloggers accept 0-2.5vdc inputs. Arduino outputs PWM.. thanks!?
I'm working with a university and they love their Hobo's and I don't blame them... they're pretty straight forward to use...
I'd like to write to the Hobo... here's the hobo analog inputs: 0 to 2.5 Vdc; 0 to 5 Vdc; 0 to 10 Vdc; 4-20 mA
Hobo stats: http://www.onsetcomp.com/products/data-loggers/u12-006
Analog channels: 0 to 2.5 Vdc; 0 to 5 Vdc; 0 to 10 Vdc; 4-20 mA
Accuracy (logger only): ± 2 mV ± 2.5% of absolute reading; ± 2 mV ± 1% of reading for logger-powered sensors
Resolution: 0.6 mV
Sample Rate: 1 second to 18 hours, user selectable
Time accuracy: ± 1 minute per month at 25°C (77°F), see Plot A
Operating range: -20 to 70°C (-4° to 158°F)
Operating temperature:
Logging: -20° to 70°C (-4° to 158°F)
Launch/readout: 0° to 50°C (32° to 122°F), per USB specification
Humidity range: 0 to 95% RH, non-condensing
Best Answer 8 years ago
The short answer is that you feed that PWM signal through a simple low-pass filter, the kind made from just a resistor and a capacitor. Such a filter will take out the quickly switching on-off, AC component, of your PWM signal, and leave only the DC part, which is just the time averaged voltage.
Regarding the long answer, I did some searching via Google(r),
http://www.google.com/search?hl=en&q="low+pass"+arduino+pwm
guessing maybe someone had already gone to the trouble of explaining this topic in greater detail, and I found this page, which is specific to the topic of low pass filtering your Arduino(r) 's PWM outputs. Um, here:
http://provideyourown.com/2011/analogwrite-convert-pwm-to-voltage/
And I'm hoping that page will tell you everything you want to know, or at least get you going in the right direction.
Answer 8 years ago
thanks!
8 years ago
hokai...
so put a big smoothing capacitor and resistor on the analog output and you have a value from 0-5 volts. Make it into a resistor divider and you can make it go from 0-2.5 volts.
Most serious question, why not get a sensor that outputs an analog value? An arduino (atmega) isn't a particularly good sensor. If you already have an analog output sensor then you could again use a resistor divider to drop your (probably) 5 volt output to a loggable 2.5
Answer 8 years ago
thanks for taking the time to answer!!
