158Views9Replies
Author Options:
How do I wire this AC motor to a UK plug? Answered
When wiring this 220V, 60rpm AC motor to the mains, it turns perfectly with the live and neutral wires connected to terminals 1 and 2 and with the earth wire disconnected from terminal 3, however it does not turn when the earth wire is connected to terminal 3. How do I resolve this when wiring it to UK mains?
steveastrouk
steveastrouk
4 years ago
It should still have an earth connection, put it on one of the mounting screws when you assemble it with a crimp on ring terminall
iceng
iceng
Answer 4 years ago
+1
Ditto, while I would think the 4 mounting mounting holes would mate with the assumed metal frame to provide that earth protective ground...
A frame, that links the low RPM + Torque reaction, with a [ stop, start or reversing switch ] that supplies the safety ground at the point power wires enter the machine.
Steve you would know. Are the UK tools, lathes and heavy machines double_insulated or how does England provide a safety ground to a two wire outlet ?
rickharris
rickharris
Answer 4 years ago
We don't have 2 wire outlets in the UK any more. All wall sockets have to have an earth. Even lighting circuits will be twin and earth cable with the frame/pattress box of the switches or sockets earthed,
Although many hand tools are double insulated all metal bodied tools like a lathe will have to have the body earthed even though the motor may or may not be double insulated.
In general Steve is right a crimped tag should be inserted between the motor body and the lath mounting to carry an earth connection. I would also clean off the paint there to give a good earth to the motor frame as well.
iceng
iceng
Answer 4 years ago
Thanks Rick,
I can now throw away those 2 prong travel converters that clutter my shelves.
rickharris
rickharris
Answer 4 years ago
They fit other parts of the world!.
CassiaD
CassiaD
Answer 4 years ago
Thank you everyone. This has solved my problem perfectly.
iceng
iceng
Best Answer 4 years ago
Looked it up on google image search.
Use 1&2 for clockwise rotation..
Use 2&3 for CCW counter clockwise rotation...
Josehf Murchison
Josehf Murchison
Answer 4 years ago
Looks like a capacitor run reversible motor made for a permanent reversible hookup.
Live 1
Neutral 2
Ground body
Reverse direction:
Live 3
Neutral 2
Ground body
"Counterclockwise"
iceng
iceng
Answer 4 years ago
And the pictures.
Click on them to see all !
CassiaD
CassiaD
4 years ago
Thank you for your reply. I have since had help solving my question by connecting the earth to motor housing and other wires to terminal 1 (or 3 to reverse direction) and 2.
