216Views6Replies
How do i connect bypass diodes to my series/parallel PV panel?
I have 20 solar cells of 0.45V at 100mA i have connected the first string in series so this will give 1.8V at 100mA with 5 strings horizontally this total of my PV is 1.8V at 500mA my question is how do i connect bypass diode to this it is a 4x5 panel at 180*130 a diagram will be great thanks
6 years ago
By[ass diodes? What do you need to bypass?
If you mean protection diodes so that power from a battery doesn't push back into the panel and destroy the cells than all you need is a single diode on the main cable coming from the panel.
Answer 6 years ago
i am just analysing the I-V curve to see different parts of shade therefore i need to know how to connect the bypass diodes to my series/parallel PV panel to show comparison
Answer 6 years ago
i hope the drawing help just want to know if this is correct
Answer 6 years ago
Just keep in mind the voltage drop across each diode. The more diodes you have on the panel the less voltage you'll get out of them.
Answer 6 years ago
how shall i connect these diodes also im using schotkky r46
6 years ago
I made a solar array out of garden lights Instructable that might interest you.
https://www.instructables.com/id/Making-a-1-Watt-Solar-Array/
As well as an instructable on repairing solar cells.
https://www.instructables.com/id/Repairing-Solar-Cells/
Joe
