679Views2Replies
How do i determine the resistors needed to reduce a 9 volt battery to 2.5 milliamps?
I'm looking to make my own Transcranial Direct Current Stimulation device.
8 years ago
With Division!
In all honest, if you can't understand Ohm's Law, maybe you should take a step back.
8 years ago
You can not reduce voltage to current ! !
You can limit the output current flow of a battery
by putting a resistor in series with the battery. R=V/I=9/.0025=3600 ohms
BUT as the battery discharges your resister will also lower the cranial
milliamps you so desperately need to think you are evolving. .
You should use a superior constant current regulator like
an LM317 three pin IC.
This will deliver a 2.5ma cranial current down to a 5 volt dead battery.
A
