109025Views5Replies
Author Options:
How do i join 2 pieces of metal without welding? Answered
I am going to attach 2 metal tubes ( 1 aluminium and 1 steel) to eachother without welding, as i am only 15. how do i do this the best way? i need them to be very strong as they are forming a steering rod.
ThaNorwegianDude
ThaNorwegianDude
11 years ago
the aluminium used to be a handlebar to a bike. its pretty strong. thnx for the answer :D
jeff-o
jeff-o
11 years ago
The best way would be to drill holes through each and run a bolt through them. If that's not possible then I guess you could try JB Weld....
Re-design
Re-design
11 years ago
Over lap the pieces a couple of inches if they slide together and bolt them together. If they are the same size then find a rod that fits inside them or a pipe that fits the outside and use two bolts in each tube thru the pipe. You could use a square tube or a piece of angle iron if need be.
