558Views25Replies
How do i put pictures on my computer without restarting it???
Every time i put pictures on my computer, i have to restart it again. Even when i put my SD card into the slot in my computer it doesn't detect it, but then i restart it and it detects it. I want it to be able to detect the SD card without me having to restart it. Help anyone???
10 years ago
Punch it.
10 years ago
Windows has a habit of trying to give external devices the same drive letter. You'll need to give the device a new drive letter. To do this:
> Connect the device to your PC
> Right-click on My Computer and select Manage.
> Select Disk Management
> Select the drive you want to change
> Right-click on the drive in the list
> Click “Change Drive Letters and Paths"
> Click Change button
> Select an new unused drive letter from the drop down list
> Click Yes on the confirmation screen
If you have auto play enabled, you will get the normal pop up dialog asking what you want to do.
Answer 10 years ago
Thanks! So i put the SD card in, then do this?
Answer 10 years ago
Yep.
Answer 10 years ago
i fixed the problem....
Answer 10 years ago
So, what fixed it?
Answer 10 years ago
I hooked my camera up to the computer on a USB cord....
Answer 10 years ago
What were you doing before?
Answer 10 years ago
I was just taking the SD card out, and putting it in the computer. But now I hooked the entire camera up to the computer....
Answer 10 years ago
Oh, OK. I assumed you had tried that already from the question. Whoops. Shouldn't assume anything.
Answer 10 years ago
The SD may need to be inserted for the 'drive' to show up in the list to get a letter.
Answer 10 years ago
I fixed the problem.
BTW- thanks for my 3200th comment!
Answer 10 years ago
...and thanks for my 1748'th comment!
Answer 10 years ago
LOL!
I have a lot more :)
10 years ago
Having read the other comments - is this a cheap card reader or something better?
L
Answer 10 years ago
What do you mean?
Answer 10 years ago
I had a cheap card reader that I took out because it stuffed-up some of my cards...
L
Answer 10 years ago
Oh! No, mine is good...
10 years ago
Are you running Windows Vista? This is a known issue with Vista, and there is a hotfix available. Go to Microsoft.com and install the most recent Service Pack, and that should fix it.
If you're not running Vista, post some more details, and somebody may be able to help you anyway.
Answer 10 years ago
no, I'm not on vista, and i don't know what version my computer is.....
Answer 10 years ago
When you start it up, what does the splash screen say? That will at least tell you what OS you're on. Or, Click on Start ==> All Programs ==> Accessories ==> Run, and then type winver in the box that appears. That will give you better information.
Do you get any kind of error message when you insert the card? Does it appear in Explorer at all? After you restart, do you get any messages about the card? Any info at all would be helpful.
Answer 10 years ago
I am on Windows XP.
And no, there isn't a message when I insert it, and doesn't appear in Explorer. I don't get any messages about the card, the only info i get is when i put the card into the computer after i restart it, a green light goes on on the computer thing. That's all i can say...
10 years ago
Answer 10 years ago
Also you should be able to make the computer read the device by opening MY COMPUTER, then double clicking the device in the list.
If the device is not shown on the list then your computer is not installing it properly. You can make it install by going into the "system tab" in the "control panel" then "hardware tab", click on "device manager" button then click on "Computer" in the list pick "Action" tool bar then pick "scan for hardware changes" in the menu.
Answer 10 years ago
Nope, it doesn't know that the memory card is in the computer, so i can't right click the device i want.
