111744Views16Replies
Author Options:
How do multi colored led lights work? Answered
I was wondering how do multi colored led lights light up the different colors, and if it would be hard to make.
daktuh
daktuh
3 years ago
Thank you, Oliver. I have been wondering about how led's work for a while now. Your explanation was concise and very easy to follow (for a non-engineering type.)
BenN28
BenN28
5 years ago
But LED's are different colours because of the casing, so how can RGB LED's be different colours with a clear casing?
OliverB48
OliverB48
Answer 4 years ago
Some LEDs are tinted but that's only to make it easy to see what colour they are when unpowered. For the tint to act as a filter, this would require white light to be emitted, which requires a lot of energy since white light is made up of a mixture of every wavelength in the visible spectrum. It's only recently (since around 2005 I think) that we've been able to make blue LEDs, since blue light is high energy, it's easier to produce light of lower energy (greater wavelength) which is why if you look at old products that contain LEDs they are always red, which is the lowest energy light in the visible spectrum. Later we got green LEDs and that's when you started seeing LEDs that could emit red/orange/yellow/green light, this works by having two LEDs in the same package, one red, one green, and varying the intensity of each to replicate different colours. The same trick is used to replicate white light (and hence any colour) by adding a blue LED to the package.
So why did we have to wait so long to get red green and blue LEDs? Well, this comes down to way LEDs produce light. Unlike an incandescent bulb (those near-extinct bulbs with the thin curly wire filament between two prongs), which emits more and more of the EM (electromagnetic) spectrum as it heats up, LEDs only emit a specific wavelength of light, which is much more cost-effective and produces far less wasted light in wavelengths we can't even see.
The wavelength of light emitted by an LED depends on (stay with me here) the chemical composition of its doped semiconductor layers.
What is a semiconductor? (skip this paragraph if you already know) A semiconductor is a material that, as the name suggests, lies somewhere between a conductor and an insulator, in terms of electrical conductivity. But how can something "sort of" conduct electricity? To understand this we need to understand why some materials conduct electricity at all while others don't. The conduction of electricity is essentially the free movement of electrons; for an electron to move to another atom it requires a certain amount of energy (see Fermi level). In metals, electrons are already sat around this energy level so it's easy for them to leave their atom. In electrical insulators, electrons sit at energy levels far below the required energy, making the jump up to the conduction band would take an enormous amount of energy. So you've probably guessed that for semi-conductors the gap is much smaller, it wont conduct electricity unless enough energy is given to its electrons to make the jump. Transistors exploit this feature of semiconductors to allow current to be stopped or allowed through at will.
Quick explanation of transistors. (Not strictly necessary to understand LEDs but transistors are what really started this all so it helps to understand them.) The three pins on a transistor are called Base, Collector and Emitter, the collector and emitter pins are at either end of the pathway through the transistor, but a semiconductor bridges the gap. Current coming from the collector alone is not enough to make it over the gap to the emitter, current delivered to the base is what charges up the semiconductor bridge, giving it enough energy to allow electrons to pass when they come through from the collector.
Back to LEDs. I said the colour of the light emitted by an LED depends on how its semiconductor layers are doped. Doping is when you a little bit of one element into a material made of another element to change its behaviour—like how putting salt on your chips changes their taste—doping semiconductors with different elements can change the size of that energy gap we talked about earlier.
It is the electrons themselves that produce the light, or rather they emit photons when they lose energy, and the wavelength of light emitted depends on the energy of the photon, and the energy of the photon depends on the energy lost by the electron. Electrons must lose energy to drop into lower energy levels within an atom, electrons like to drop as low as they can so they quite happily emit photons to shed energy. The trick is finding the right doping balance to train the electrons to emit the wavelength of light that we want. That's why it took so long to get those shorter wavelength (higher energy) colour LEDs, because it's difficult to find doping that trains electrons to emit such high energy photons instead of lower energy ones.
DonkeyOber
DonkeyOber
Answer 3 years ago
I know this is an old post but, please do some research before posting things that you think you remember. Blie LED have beem around since the 70's and the development of different colered LED had nothing to do with the energy output. Different colors require different levels of doping and the techniques necessary to make blue LED (GaN) was unknown during the 60s when GaAsP was being used to create red/amber LED.
Stupidscript
Stupidscript
Answer 4 years ago
This is a really nice, understandable post on this topic. Thanks!
CreativeC2
CreativeC2
4 years ago
how to make multi color led ?
ElectricProjects
ElectricProjects
7 years ago
A colour changing LED isn't one LED in a package but three LEDs along with a small computer to drive them. The LED is made up of red, green and blue LEDs each of which can be controlled by a microcontroller. Since the two legs on the LED that supply the power are connected to the microcontroller and not the LED elements a current limit resistor is not required.
The microcontroller is able to turn each of the colours on or off, so if the red LED is turned on then the output from the colour changing LED is red. When the blue LED is turned on it is blue, if both the blue and red LEDs are turned on then the colour changing LED is a shade of purple (called magenta). Similarly combining red with green gives yellow and blue & green gives cyan.
Although the colour changing LED uses the six colours mentioned above, it slowly changes from one to another. This is still done using the three basic red, green & blue elements. If the red LED is combined with the blue LED, but the blue LED is only driven at 50% of its normal brightness then a colour half way between red and magenta is generated.
Whilst the red LED is left turned on, if the blue LED is slowly taken from 0% brightness to 100% brightness then the colour will gradually change from red to magenta.
If a standard LED is turned on and off very quickly, say 100 times every second then as far as the human eye is concerned it looks like it is constantly on. If the amount of time the LED is on for is the same as the time it is off for then it will be on for 50% of the time and 50% of its full brightness.
This same method can be done with the three LED elements inside the colour changing LED. This means it is possible to combine any amount of the red, green and blue to give the desired colour. Looking once again at the change from red to magenta, if the blue LED starts mainly turned off, goes to being on and off in even amounts and then to mainly being on.
kelseymh
kelseymh
11 years ago
Each individual "RGB LED" light has three separate LED chips embedded (red, green, and blue), each with a pair of leads (some just use four leads, with common ground), all behind a diffuser.
By running independent PWM to each chip, you can mix different intensities of red, green, and blue to get any color.
seandogue
seandogue
Answer 11 years ago
+1 (although one *could use analog control as well)
kelseymh
kelseymh
Answer 11 years ago
Really?  How do you use analog (voltage or current variations) to change the intensity of an LED?  Or do the RGBs come with a built-in ADC and PWM circuit?!?
steveastrouk
steveastrouk
Answer 11 years ago
Err. This will do it, three of 'em. light output varies nicely with current.
kelseymh
kelseymh
Answer 11 years ago
Thank you, Steve!  There's a lot about practical (as opposed to theoretical :-) electronics I still have to learn.
steveastrouk
steveastrouk
Answer 11 years ago
You're welcome. Incidentally, I have no clue why the picture now says PLOKI on it ?
EdurusFas
EdurusFas
Answer 10 years ago
WOW!  Soo much info :) COOL:)
The LEDs that I've seen that change color - only have two leads coming from them - which is why I thought that maybe they used varying voltage to change the color - but would that even make sense?
BTW- Sorry for the late reply- I asked the question, and then I became very busy with classes.
Thanks everyone! :)
seandogue
seandogue
Answer 11 years ago
The intensity of a single LED P/N junction in the RGB is governed by the forward voltage/forward current (of which there are three). If you drive the forward voltage using an analog source, it results in the same behavior as the effect that a PWM produces (which is in actuality little more than an analog voltage due to intrinsic RC..you could look at it like calculating the average value of a non-symmetric square wave of freq f, remembering that the square wave is 0-V rather than -1/2V-1/2V) ) . Also, as a reminder (although you know this already) RGB leds are just three leds with a common cathode. can be driven using constant current, voltage, or PWM modulated sources...)
But I definitely agree it's much easier and afaik more efficient to accomplish using PWM, or three channels of  D/A. Color matching makes it a bit more complicated, since one needs to do more footwork but that's abit outside the scope here.
Here's a simple experiment (and fun!) you can do with a single LED...
Use a 10-turn pot (one of those little 3-pin bourns trimmers for instance) as the limit resistor in a simple LED circuit (power supply, resistor, led and back to common on power supply). I deally one would use a trimmer and a fixed resistor to ensure that the led doesn't experience an overvoltage situation, but if you're careful it's not necessary
Now, set the pot by using calculations before applying power to ensure that you don't overdrive the led. (note: that's the "if you're careful")
Now, when you power-up the supply, play with the pot. You'll actually see a variance in the color with most leds...not talking the significant change that occurs when you're  at overdrive and they go orange, but the variation within the "useable" range...We'd consider it dim vs bright at first glance, but if you put your thinking cap on and consider that an RGB led is blending three leds power independently (with a common return/cathode)...
That's all that's going on with RGB leds... you go from
off thru bright on each color, which is mixed with one or more of the other leds to produce the effect of the color that our eye dithers out.
It's not quite so simple to reproduce known colors consistently with multiple "arrays" in which additional bias can be applied, sets of RGBs are selected, etc...but the basic situation is right there.
