6201Views7Replies
Author Options:
How do you build a BFO for a shortwave Radio? Answered
I was on amazon looking to buy a better shortwave radio and this guy on there said "I did build a separate little circuit called a bfo. When I hold this next to the radio, I can understand radio amateur transmissions (around 7 mHz). " and I would very much like to be able to do the same, So how would you build such a thing. Thank You. All the best.
framistan
framistan
Best Answer 7 years ago
BFO just means a "Beat-Frequency-Oscillator".... It's just an oscillator. In ham radio, when morse code is sent, it is just a simple carrier frequency with no modulation. If you tune in to it, it just sounds like someone keying up a mic and not saying anything. When you bring an oscillator tuned 1000 hertz higher or lower than their transmission, you hear the difference in the 2 frequencies... so you hear the tone. I think this works for ssb single-sideband transmissions as well. Most good shortwave radio receivers have a switch to turn ON and OFF the BFO. It is not needed on standard AM or FM transmissions.
Graydant
Graydant
Answer 7 years ago
That explains it, and one my radio's has such a switch but I never knew what it was for, Now I don't need to just buy another radio for it. lol
I'm still new to shortwave, have only had my two SW radio's for a year. I'm going buy a better radio still but haven't decided I'll look for that to be on it. Thank You..
steveastrouk
steveastrouk
7 years ago
Why ? Are you actually trying to listen to morse ?
Graydant
Graydant
Answer 7 years ago
Yes. I'd like to be able to.
EI4GOB
EI4GOB
Answer 5 years ago
Good for you! If you still have to learn Morse code then this Windows program by Ray Goff G4FON is the best way in my opinion.
http://www.g4fon.net/CW%20Trainer.htm
73 Fionnbarra EI4GOB
delta8941
delta8941
7 years ago
If you want a nice sensitive and portable HF receiver try the Grundig G3. This radio has the ability to listen to SSB modulated signals. If you like to try your hand at building a BFO circuit here are a few good easy projects. With these you can turn almost any department store AM/FM receiver into a HF receiver; provided you detune the radio and get it into the correct band of frequencies first!
http://home.alphalink.com.au/~parkerp/projects/projbfo.htm
http://www.pan-tex.net/usr/r/receivers/sbfo.htm
(This is a better circuit. A 160pF variable capacitor is needed from an old AM/FM radio, the IF transformer is NOT needed, buy a few 455khz ceramic resonators from ebay, for the JFET anything can be used, J310, 2N3819 etc)
This pages contains a very simple HF receiver circuit:
http://www.ke3ij.com/JFETrgn.htm
