7443Views10Replies
Author Options:
How do you connect a motion sensor up with a motor so that when the sensor goes off, it also powers the motor? Answered
This is a project I'm doing for my kinetic sculpture class.  Ideally I would like to have the piece set up in the hallway and have multiple motion sensors so that when it detects someone walking by it, it powers an attached mallet of some sort that hits against the wall to make a beat.  Let me know if you need a better/ more detailed description!
Any help would be greatly appreciated!!
7654321
7654321
9 years ago
use a microcontroller?
JarnelangelaR
JarnelangelaR
Answer 2 years ago
i mean i want to control servo motor using PIR MOTION IN RASPBERRY PI 3..IF THE Pir motion sensor. if someone make motion into the PIR THE SERVO MOTOR ARE MOVE INTO 90 DEEGRE AND IF THERES NO MOTION AUTOMATICALY GOING BACK TO ORIGINAL POSITION
BriannaSchmall
BriannaSchmall
Answer 9 years ago
could you explain a little more? I'm very much a beginner when it comes to this kind of stuff.
Thanks for the feedback thus far!!
AndyGadget
AndyGadget
9 years ago
These PIR sensors would be ideal.  They give an output pulse of several seconds duration when they detect a person in the field of view.
You would have to have a bit of additional circuitry (check out 555 monostable) to make the pulse more controllable, and a drive circuit to power a solenoid to move the mallet.  (The bigger the mallet the harder this bit would be.  What sort of scale are you thinking of?)
JarnelangelaR
JarnelangelaR
Answer 2 years ago
how to control a servo motor in a PIR MOTION USING RASBERRY PI 3
BriannaSchmall
BriannaSchmall
Answer 9 years ago
this is starting to help. How exactly would the PIR sensor hook up to a motor? If this is a complicated process, I could alter my project a bit. I've just never worked with motion sensors or anything of that sort but would love to incorporate them into my project for my kinetic sculpture! Thanks for the help that you've already given me!
AndyGadget
AndyGadget
Answer 9 years ago
The PIR gives out a signal when it detects a person moving, but that signal has very little 'oomph' behind it - Nowhere near enough to move the weight of a mallet.  It needs additional circuitry to 'gear up' the power.
It will also trigger several times as the person is walking by. That may be what you want, but it's not too difficult to tailor it to your needs with a bit of extra circuitry to control how many times and for how long.
The task is not particularly difficult, but as I'm pretty sure there is no off-the-shelf solution to do this it would take a bit of designing, which I really do not have time to do - sorry.
If this is a college project, is there an electronics department which could help you with the technicalities, or possibly a joint-effort with a technically minded student?
(The way I would do it is with 2 cascaded 555 monostables for the signal conditioning, then a MOSFET driver stage with spike protection. )
BriannaSchmall
BriannaSchmall
Answer 9 years ago
Thanks so much for your help! I think I am starting to get it.
JarnelangelaR
JarnelangelaR
2 years ago
How to control servo motor With the PIR MOTION THAT CAN CONTROL THE SERVO TURN TO 90 DEGRE AND
BRINGBACK TO ORIGINAL POSITION .
