2244Views7Replies
How do you hotwire a car?
Preferably a Chevy El Camino.I lost my keys and I dont want to pay for a lockpicker or new keys.Help would be nice.
9 years ago
I'm pretty sure that all you need to do is short the leads that go to the ignition key switch
11 years ago
an El camino? those are easy. take a good knife and a skrew driver. get the knife and use it to pry open the ring around the ignition, then stick the skrew driver into the hole that is left.
11 years ago
been a long dam time since I last had to hotwire a ride , and aint too likely i'll be doin' it again very soon either !!
11 years ago
Quickly press the R2 and L2 buttons on your controller.
See? Videogames can teach you things!
11 years ago
bypass th' ignition switch by runnin' a wire from th' + battery post to th' distributor , then to start th' engine by "shortin'" th' posts on th' starter motor !
To stop th' engine , pull th' jumper wire away fron th' battery !
Answer 11 years ago
> bypass th' ignition switch by runnin' a wire from th' + battery post to th' distributor ...
. Some, if not all, El Caminos use a dropping (ballast) resistor and running straight to the battery will cause premature failure of the coil (and points, if it's old enough).
. Find the ballast resistor (usually on the firewall) and run a wire from the battery to the key side of it.
11 years ago
This should be what you need:
http://www.wikihow.com/Hotwire-a-Car
