166Views4Replies
Author Options:
How do you test effective range, resistance and bandwidth for the morse code telegraph by johnnyrockstar? Answered
I have made the morse code telegraph machine and need to test the effective range, so I have to work out the resistance and how far apart the bases could be to still work.  I also have to test the effective bandwidth.  Can anyone help me with how i go about doing this?  I would really appreciate any help.
lemonie
lemonie
10 years ago
If you used the signal line to switch a transistor operating the light / buzzer, you'd have much less current in the signal line and less voltage-drop.
L
orksecurity
orksecurity
10 years ago
Range: Since this is a wired system, it's a question of how much voltage is needed to operate the buzzer versus how much resistance each foot of wire will add. If you need more range you can add more batteries, though of course you don't want to go above a safe voltage.
Bandwidth: How fast is you "hand" -- how quickly can you bang out morse code accurately? How quickly can you understand it? For a beginner, those will probably be the limiting factors. For someone more experienced, the fact that this paper key is not very responsive, and that the buzzer takes a moment before it starts sounding, will be the limits -- which is part of why traditional telegraph sounders used a click rather than a buzz, and why the traditional sending key is a more complicated (and precise, and adjustable) mechanism than the simple paper-spring key shown in that Instructable.
Lizzieg22
Lizzieg22
Answer 10 years ago
Thankyou very much for that.
So to figure out how much resistance is in the circuit, can I just use the formula V=iR?
And could I use an ammeter to measure the current? How would I need to attach it?
orksecurity
orksecurity
Answer 10 years ago
Easier to use an ohmmeter. (When the battery is not attached, of course.) That handles the voltage/current correlation for you.
But, yes, you could do it by hand. First measure the voltage across the battery when the circuit is closed (it's probably less than the battery's rated output), then put the ammeter in series with the battery and measure how much current is drawn. Calculate appropriately.
(I believe there are instructables describing the uses of a multimeter. They'll answer this question in greater detail.)
