8050Views2Replies
Author Options:
How does a plasma globe work ? Answered
orksecurity
orksecurity
11 years ago
https://www.instructables.com/id/Maker-your-own-Lightning-Globe!/
Basically: Small tesla coil, producing high-frequency high-voltage low-current signal. Discharges from this ionize a gas, or gas mixture (exactly which depends on the globe), creating a charged plasma. Current flow through that plasma heats it, causing it to glow -- just as a static-electricity spark (or a lightning bolt) glows. The bulb may or may not have a conductive coating to act as the other terminal for this ionizing current. If you come near to or touch the globe, you act as a large ground and some current flows to you, altering the pattern of ionization and thus the light patterns. (You may feel the current as a slight prickling where your skin touches the globe; as with static electricity there isn't enough current to do you any harm.)
Bartboy
Bartboy
Answer 11 years ago
And if you wrap the globe in tin foil, then touch it, it will burn you a little.
