9028Views22Replies
Author Options:
How does one create a batch script that will run under unicode format? Answered
If you want to use special characters provided in command prompt and implement them in a batch script, how would one run a batch script in unicode format? Once it is created, a batch script must be run in ANSI encoding. But the special characters will be lost! Answers?
Arbitror
Best Answer 9 years ago
Yes, you can echo "< " in batch. All you have to do is put a caret before the special symbol. But, I can't type a caret on Instructables, so I will use this: /\.
It's that simple!
TATcreatorArbitror
Answer 9 years ago
You have the best answer so far, but what we need is to display special unicode format symbols that can be generated in a command prompt window, but strangely will not save as a unicode batch file and run.
ArbitrorTATcreator
Answer 9 years ago
Oooohhh, I see.
Good luck on that one! I don't even use batch anymore, I've moved on to more modern programming languages.
Thanks for best answer by the way!
TATcreatorArbitror
Answer 9 years ago
Good luck with your own programming. Also, be on the lookout for TAT 2.4.2: TAT Reloaded coming in February...
Or sooner!
ArbitrorTATcreator
Answer 9 years ago
Even though I don't "batch" any more, I can't wait to see how far you guys have gotten on your project!
lemonie
10 years ago
Is the output ultimately ANSI or can you get the .bat to produce a Unicode output?
What do you want to do anyway, there may be a better way of doing it?
L
TATcreatorlemonie
Answer 10 years ago
We rquire to run an MS-DOS script in Unicode encoding. Nothing more, nothing less.
DELETED_GuardianFoxTATcreator
Answer 10 years ago
Sorry, MS-DOS is limited it what it accepts as input. There are ways around the issue, but plain and simple is ASCII-ANSI or nothing. Like lemonie asked, please explain what you're trying to do so that we may help you further.
lemonieTATcreator
Answer 10 years ago
At a guess you're not saying any more about this because you're worried that someone will steal your intellectual property? If ultimately you want to display non-ANSI characters in a DOS shell - you're out of luck. Have you considered programming the same application in something else?
And have you run this: "telnet towel.blinkenlights.nl"?
(Do something with creworksinc.com - it looks bad with all the default text in there)
L
TATcreatorlemonie
Answer 10 years ago
Yes, we have seen the film, as incomplete and unstable and back door-opening as it is, when we were mere "script kiddies" about four years ago. We would be careful, anyone else may have been insulted with the comment you left. All we wish to do is display a special character in a batch script without switching to unicode or find a way to produce a batch script in unicode. We have tried cmd /u in a special comspec interface provided by the main system root, however to no expense.
lemonieTATcreator
Answer 10 years ago
Oh well good luck with whatever it is anyway. L
lemonieTATcreator
Answer 9 years ago
And you!
Did you solve this problem?
L
TATcreatorlemonie
Answer 9 years ago
No, but we have managed to work around the issue. We really don't need an answer anymore, but we are willing to give you best answer if you can either provide us with an explanation as to why it is impossible, or better still, solve the problem.
lemonieTATcreator
Answer 9 years ago
Let's leave it open. Your work around is..?
L
TATcreatorlemonie
Answer 9 years ago
Just using ANSI symbols, like = or *.
ArbitrorTATcreator
Answer 9 years ago
Insulted? Seriously? On the scale of "be nice" I would give it a neutral...
        V
                                ~Nice~             ~Neutral~         ~Darth Vader~
lemonieDELETED_GuardianFox
Answer 10 years ago
Damm - another disappearing comment. You said essentially what I did yesterday (which has vanished) - thanks. L
TATcreatorlemonie
Answer 10 years ago
We type a special character ☼ in a batch file, but it turns out wrong when we keep the character ☼ and try to save in ANSI because ☼ is a unicode character and a batch file must be saved in ANSI or the batch file will not work.
