690Views7Replies
Author Options:
How does thermoplastic work with curved surfaces? Answered
I was thinking about getting some thermo plastic. However, I wasnt sure if it would get creases in it if used over a spherical surface. If theoritically I put some thermoplastic over a bowling ball, would it match the curve of it? Thanks!
-xD
rickharris
rickharris
Best Answer 10 years ago
I am assuming you want to make a globe roughly the size of a bowling ball?
Using a sphere isn't the way to do it!.
To make a globe you will need to make it in 2 halves. You will need either half a sphere as a pattern OR you can reverse the system and use an open circle as a blow mould.
Clamp it onto the plastic and heat the thermoplastic up to a temperature where it is rubbery and drooping then blow through the circle from underneath forming a perfect half sphere.
steveastrouk
steveastrouk
Answer 10 years ago
I've also seen hemispheres made by slumping through a ring.
Steve
lemonie
lemonie
10 years ago
You could do this right, but it does depend on what you're using and how - what have you got?
L
! xD !
! xD !
Answer 10 years ago
Well, Im very unfamiliar with thermoplastic and Ive not bought any yet, but I was thinking about using it to make something similar to scoochamaroo's Creepy Mask instructable, but I wanted to make it a whole helmet type of mask rather than simply a face mask. What do you suggest?
lemonie
lemonie
Answer 10 years ago
I'm not very familiar with thermoplastic, but you've got good instruction in that Instructable - ask Sarah?
For masks, I've used paper & PVA - it takes a long time but you can get what you want.
L
RavingMadStudios
RavingMadStudios
10 years ago
Depends on which thermoplastic it is and how you form it. Working with Polymorph/Friendly Plastic is very different from vacuum forming, but both are thermoplastic techniques.
