660Views5Replies
Author Options:
How important is the forward voltage rating on a crystal radio diode.? Answered
I have been researching how to build a crystal radio, and have built a few from schematics I have found on the web (though none have worked so far). The thing that is confusing for me is the range of forward voltage ratings I have found. Some of the part numbers I have come across such as 1N34A show a forward voltage of 1 volt. While others recommend 500mV and others as low as you can get.
With so many instructions saying different values for best results. Is there a recommended rule of thumb for choosing a diode for a radio detector?
iceng
Best Answer 5 years ago
Trying to visualize the circuit.
Any way the diode has to pass a tiny ( small voltage ) audio signal and a low forward germanium semiconductor P N junction ie Diode helps in that respect.
The next thing is; the diode should not be constructed to carry large currents which would make a capacitive absorption of a weak signal. You want a small signal diode much like the 1N34A.
I read somewhere the 1N34A is a point contact device which you would want..
You say you are having no working results. Perhaps the materials you are using for the back board have a weak resistive leakage upsetting your efforts.
Even building on glass a finger swipe can leave an oily residue to upset a circuit with unwanted electrical pathways.
Keep your parts clean and isolated.
rickharris
5 years ago
You need to look for a germanium diode. It looks like this
You can find projects to make foxhole radios that will tell you how to make a contact diode from raw materials.
PS I am an electronics engineer and have never done well with building radios - It's very hard to get right.
icengrickharris
Answer 5 years ago
Great picture Rick, I was not able to follow it to the source article, can you help ?
A
atrumbloodrickharris
Answer 5 years ago
Thanks, I was already aware that I needed a germanium diode. I should have mentioned that in my question.
However I am still curious as to the forward voltage variances I've seen.
atrumblood
5 years ago
Thanks for the replies guys.
I dug through my assortment of diodes and found 3 Germanium Diodes. I am having trouble locating the data sheet on one of them.
Its part number is 0A70.
I Also found two of 0A79
and one 1N87.
Hopefully I will get better results with these.
framistan
5 years ago
The 1N34 is a pretty old SIGNAL DIODE. I used to have a pill bottle full of them. You might try calling gateway electronics, a local hobby-electronics supplier here in st Louis, Missouri. their website is gatewayelectronics.com and their phone number is 1-800-669-5810. They might have some in their very large parts counter, and they won't cost much, if they have them.
