102Views5Replies
Author Options:
How is a large building wired up? Answered
So, recently, I was at school, and trying to use my laptop charger ( I was the only person in the room to be doing so)
However, it didn't work.
Using it at home, however, it instantly kicked the RCD or safety switch thing off, switching off everything running off the mains
Upon further inspection, I found that the power cable had been damaged, so that the active wire was in contact with the ground wire.
My question is, how come the power at school didn't get shut down completely ( the lights were still on, and wall outlets in other rooms around the school still worked) but at home, everything was completely shut down.
I thought that there'd be at least a fuse or something, if not a safety switch...
steveastrouk
steveastrouk
Best Answer 9 years ago
Somewhere as big as a school may well have a breaker or fuse per room, and you tripped it and since it only served your room, the room circuits went dead.
Domestic circuits are often protected on a "larger" scale. I would actually be quite worried if the main breaker trips, and not the sub-breakers. You may need to get the panel looked at.
Steve
Re-design
Re-design
Answer 9 years ago
And when you used it at school it may have only been a loose connection. By the time you got it home and plugged it in it had changed to a shorted connection.
I'd be very surprised if it was shorted at school and didn't trip a breaker but you didn't get any sparks and smoke.
orksecurity
orksecurity
Answer 9 years ago
Agree with both. Either you tripped a local breaker (which may not have covered all the outlets in that room), or you were just lucky and didn't happen to short-circuit at that time.
verence
verence
9 years ago
The school will most probably have different circuits for lights and wall outlets and for each room / block of rooms separately. Nobody wants some dozen children panicking in a pitch black room (think early winter morning or late evening event) just because a teacher plugged in a faulty device (or some pupils tested their self-made circuit-breaker trigger).
seandogue
seandogue
Answer 9 years ago
My home is wired the same way. Lighting circuits are on separate breakers from the electrical outlets.
