1060Views9Replies
Author Options:
How is a standard transistor different from a mosfet? Answered
So I have been teaching my self the basics of electronics and I find my self confused on the differences between a standard transistor and a mosfet.
I understand the physical differences but what I do not understand is the differences in their applications?
A transistor is either ON or OFF which is controlled from the BASE and is normally OFF.
A mosfet is either ON or OFF which is controlled from the GATE and depending on the type is normally ON or OFF.
I think I might be over complicating things but based on my description of the two above.
Am I missing anything important?
iceng
iceng
Best Answer 9 years ago
A mosfet is a transistor too.
Some transistors are enhanced to be on / off  devices.
Most transistors junction and mosfet have a linear response area
that is useful for analog signal amplification ( Audio too ).
Junction transistors work with a base-emitter input current controlling
a greater output collector-emitter current, while a mosfet transistor
works with a base-source input voltage controlling a large output
drain-source current.
Hope this makes it more clear for you.
A
atrumblood
atrumblood
9 years ago
Thanks for the answers guys. I am making progress slowly.
rickharris
rickharris
9 years ago
A mechanical analogue to a transistor would be a valve of some kind that you can turn on and off or anywhere in between with little effort and control the flow of high pressure water through it.
A MOSFET would be more like doing the same by pinching the hose pip shut to control the flow of water.
In practical terms the MOSFET will have a much higher input impedance than the transistor. It draws very little from the input circuit. and is voltage controlled whereas the transistor is a current controlled device.
steveastrouk
steveastrouk
Answer 9 years ago
A MOSFET is STILL a transistor ! Its a transferred resistor, only the mosfet is voltage controlled and the BJT is current controlled.....
atrumblood
atrumblood
Answer 9 years ago
I am not sure if that makes sense to me or not about how a BJT is current controlled and a Mosfet is voltage controlled. Aren't both voltage and current values dependent on the resistance in a circuit?
Also I should have stated in my original post that I knew both were transistors.
steveastrouk
steveastrouk
Answer 9 years ago
Basically, look at it mathematically.
Ic = Hfe x Base current for a BJT (Collector current= Hfe x Base current
But for a Mosfet.
Id= Gfs x Vg ( Drain current = transconductance x gate voltage)
Steve
steveastrouk
steveastrouk
9 years ago
NO a transistor is NOT "on or off". It is an AMPLIFIER. Without feedback, and with enough ampliification, it can give the appearance of being "on and off".
atrumblood
atrumblood
Answer 9 years ago
So what is being amplified is the input or output on the base right? So a small signal on the base is mirrored in the larger input on the emitter and collector?
