447Views15Replies
Author Options:
How make the brakes of Fat Bike? Answered
I want build the Extreme Fat Bike. I have a problem in Brakes. How to makes the Brake of Exreme Fat Bike and how they fix?
steveastrouk
steveastrouk
3 years ago
Use disk brakes, like a real car.
Dani Dani
Dani Dani
Answer 3 years ago
How is the disk brake? Can you give me some idea?
Dani Dani
Dani Dani
Answer 3 years ago
you are right. But not any steel disk in the alloy rim. Or any thing where the brake pads can grip.
See this pic.
I want make brake like this.
rickharris
rickharris
Answer 3 years ago
It looks like the brake pad is rubbing on the inside of the wheel.
As the instructable doesn't tell you where the wheels cam from I think your going to find them hard to get.
I ghuess it might work like this diagram.
The cable pulls the lever down. This presses the brake pad against the inside of the wheel.
Dani Dani
Dani Dani
Answer 3 years ago
so thnx Rick Harris. Where are you from?
rickharris
rickharris
Answer 3 years ago
The disk brake is very hard to home manufacture. You would be better off buying a ready made one designed for a bike. NOTE this may require you also buy a wheel suitable for mounting the brake on.
(This from someone who has built several recumbent bikes etc and has yet to manage to implement a disk brake without buying the parts.)
Dani Dani
Dani Dani
Answer 3 years ago
So Thnx for Guide me.
iceng
iceng
3 years ago
So if you look carefully you can see the press tracks from a pair of brake pads against the inside rim of the fat wheel...
You can also see the outside of the cable mechanism that presses those pads up to friction touch the rim..
iceng
iceng
Answer 3 years ago
BTW if you click the pic 2 or three times it will enlarge, or better download it to paint program...
You do know how to weld and machine a thread ??
Dani Dani
Dani Dani
Answer 3 years ago
i see that. But i m confused. How is this brake and how to fix it. Can you give me idea how it works inside? Plz rply.
rickharris
rickharris
Answer 3 years ago
I see you have asked in the instructable, I guess that is the best you can do. There is very little in the instructable in the way of instructions.
Note big wide tires = drag.
Unless someone is willing to draw detailed plans for you I guess you will have to do that yourself.
