215176Views12Replies
Author Options:
How many Ah are car batteries? Answered
I want to know how many Amp hours a car battery has? I need to know how long I can use them for particular things.
Also how many Amps will you be able to draw from a moderate sized one? I need to know how much I can squeeze out of them before I start experimenting with them.
AMWARTWORK
AMWARTWORK
1 year ago
Hello. I have a question that needs a good clear answer.
My intention: To busk with my bass amp using a battery.
Ok so my bass amp is : 100 watt max output. 310 Watt power consumption
I have a 500 watt (1000 peak) invertor (modified wave). I read on 2 sites that its a god idea for to besafe, use a wattage 10-15 pcent on top of the power consumption value. (mine being 310 watts)
I wont be cranking the amp up loud as it produces some lovely low end sounds.
So..... For the battery, im aware of deep cycle bateries are more energy efficient (i dont mind charging it up eith my 12v charger when needed).
There is a guy called DUB FX on youtube and he walks you through his setup.
His setup is a 200 watt roland speaker combo amp. HE USES AN 800 WATT MODIFIED sine wave inverter and a 66ah 12v gel battery.
My amp is half the wattage as his.
Which battery would suit me for 3 hours of play time?
Weight isnt too much of a problem .
Thanks in advance folks of voltagery wattagery wizdom
RobB230
RobB230
2 years ago
This starts off as one of the most stupidest explanations I’ve ever seen extra inches or joke come on you can explain to the Lehman a little better than and then this try again please
aarron.willett
aarron.willett
6 years ago
what ended up being the answer?
Hour many hours can a battery pull 1 amp?
Is it better to buy a 120ah deep cycle battery for your car, if it runs accessories?
RussellS8
RussellS8
Answer 5 years ago
I know this is an old question, but I know the answer: Always use a car battery for a car. It is possible to add a second battery to power your accessories, but deep cycle batteries are not designed to start a car engine. They don't provide the high amperage that a car battery does. They are designed for energy storage and slow release, not cranking power.
iceng
iceng
Answer 6 years ago
A deep-cycle battery has an acid only extra inches below the lead plates. This arrangement lets flakes off of the lead sulfate plates collect on the bottom for a longer time due to charge / discharge cycling before the lead scrap heap shorts the cell plates and stops battery action.
A 120ah ( amp-hour ) battery can deliver 1 amp for 120 hrs OR 2 amps for 60 hrs OR 3 amps for 40 hrs OR 4 amps for 30 hrs OR 6 amps for under 20 hrs OR 12 amps for under 9 hrs...........
A 24ah battery can deliver 1 amp for about 24 hrs, OR 2 amps for 12 hours , etc
Lead acid 12 volt car batteries are fully discharged around 8 volts and if they are discharged below 6 volts they may not hold a charge reliably.
What is your accessories current load ?
Are you running your accessories with the engine running or just batteries ?
StevenL7
StevenL7
Answer 6 years ago
In what case does the a battery voltage drop? Besides temperature?
iceng
iceng
Answer 6 years ago
It's an old story for a new member about non-sealed car battery voltage as a measure of the state of charge left.
Different batteries have different discharge voltage curves
Look into 12 volt lead acid battery discharge curves.
iceng
iceng
10 years ago
Back when I worked 8 to 5 we compared lead acid battery about 13 watt hrs per pound of battery and 1300 watt hrs a pound of gasoline if my memory serves.
Andale_The_Great
Andale_The_Great
10 years ago
I would suggest checking the manufacturer website for this info because batteries are VERY different from one brand to another. On top of that there are different kinds of batteries. Marine batteries, also known as deep-cycle batteries, are made to be used without constant recharge. This means you can go spend the day on the boat all day then take it home and charge back up overnight, whereas a "standard" battery is not made to run for long on its own. Example? When your car's alternator died while driving how far did you get? Not very far.
This doesn't answer your question, but hopefully it is helpful.
lemonie
lemonie
10 years ago
You can easily get 60Ah, and 60A - they're pretty good, but have a good charger.
L
Vyger
Vyger
10 years ago
It also varies with the temperature. That is why in the winter you have a harder time starting, not only is the engine stiffer but the battery is putting out less power. In really cold climates they even use electric battery warmers to try and keep the output up. Cold Cranking Amps does not refer to the engine being cold but rather to the output of the battery at lower temps.
steveastrouk
steveastrouk
10 years ago
SSA, Short circuit amps, for a lead acid battery can easily top 1000A.
However, you can only pull that for a few seconds- long enough to fuse a wrench across the terminals.
The actual energy capacity is surprisingly small - 80Ah is pretty typical.
Steve
The MadScientist
The MadScientist
Answer 10 years ago
I thought it would be more like 40Ah but I wasn't sure.
steveastrouk
steveastrouk
Answer 10 years ago
Depends, diesels are often quite grunty batteries.
Steve
The Ideanator
The Ideanator
10 years ago
That depends on the battery.
If you want to know how much juice the battery has, a google search , a search through the manufacturers website, or a search through distributors sites, or even a call to the manufacturer/distributors with the product number/ID will usually yield a MSDS or some sort of specifications sheet of that particular battery which should tell you 1) the batteries chemistry, 2) the voltage, and 3) the Ah capacity, better sheets will also give you graphs of various aspects of the battery.
As for how much current you can draw, in a perfect system (eg there is no resistance except for the load) you could draw an infinite number of amps, but IRL the battery has an internal resistance, your wiring puts limitations on energy capacity, and a host of other reasons. you could pull an incredible amount of current, but due to the Ah capacity of the battery, you can sustain that current for only a short period. Basically, the current you can pull is only limited by the load (its why LED circuits usually have resistors).
