117Views5Replies
Author Options:
How many LEDs rated at 5V can I use on a 6 Watt Radio Amp? Answered
I there, I have a 6 watt radio amp that if I used the Voltmeter correctly is only really using 1.3 watts at it's highest volume on the busiest song.  I want to add LED lights to the dial and I'm wondering how many can I use?  I purchased LED lights rated to a max of 6V and the engineer told me that they can be used for a 5V power supply.  I would like to use as many as I can in series and will like to learn how one comes up with that number.  Thanks
javierdiaz4
javierdiaz4
6 years ago
Hi there iceng, I'm new to all of this. the LEDs already have resistors. My question I guess was really trying to figure out if I would have any issues powering these LEDs and if safety is a concern in conjuction with the 6w amp which from what I have measured is at 1.3watts at the moment and I may make some changes to make it go up to 4.5watts.
iceng
iceng
Answer 6 years ago
If you know what the voltage supply [ not watts ] of the radio amplifier then I can help.....
Here is a table ;
A 12v supply => use two leds in series
A 15v supply => use three leds in series
A 20v supply => use four leds in series
javierdiaz4
javierdiaz4
Answer 6 years ago
iceng, since It seems I'm limited to keeping one light, which is what I already have. Do you have any suggestions or ideas as how I can accomplish wiring up this 5v amp that generates up to 4.5 watts of power to speakers and that will allow me to power up a 6.3volt lightbulb that is already on the radio. What would I need? Thanksa million
javierdiaz4
javierdiaz4
Answer 6 years ago
Ha, I guess I'll use one and no in series. It's a 5v supply radio powered by an apple usb adapter and a micro usb cord.
iceng
iceng
6 years ago
You need to know the real LED voltage and LED design current, say white LED which needs 3.6v @ 20ma.
Then go to http://led.linear1.org/led.wiz and plug in
the 6 volt supply
the 3.6 volt led forward voltage
the 20 ma design current
and a 4 led array
click the wiring diagram
then [ DESIGN MY ARRAY ]
