125Views7Replies
How many different ways are there to put a handle on a tool?
I've made a wee wallpaper roller to help apply some strips of adhesive cork in my landy. And it struck me that all my home-made handles are crap. They start as ~1" dowell with a hole down the middle, but even if they're snug to start with, the shaft loosens up and the tool spins in the grip. So to save it I end up cutting a slot and snugging it up with a hose clamp. Currently I have three tools in this state. What better handle designs are there?
10 years ago
umm look on the ibles site if nothing try PVC
11 years ago
4.
11 years ago
Drill a hole in a golf ball and press onto the tool.
11 years ago
Well what your hose clamp does is what "proper" handles do, there is always a ferrule at the end of the handle to stop the things splitting. You could make one from a piece of copper pipe, and turn the wood to make a tight fit on the ferrule.
Answer 11 years ago
The problem is not splitting - handle is spinning on the shaft. So the hose clamp is supposed to squeeze down on the shaft. Another trick I tried was deforming the shaft with a file or bolt cutters before fitting to handle, and it helps but still doesn't stop the problem. Any screwdriver I've busted open has some sort of wider bit like a tang, but I have no way to duplicate that. Another idea was to cut the fat dowell down the middle, and lay the shaft inside but to put a 180 degree turn at the top, and dig out just enough of a bed to hold this, then glue and string-wrap the handle back together.
11 years ago
Or you could just put in a screw :P that oughta hold 'er
Answer 11 years ago
Yeah - my last effort I put a 1mm hole through the shaft, then put a panel nail through that inside the wood - was enough to stop the spin.
