383Views5Replies
Author Options:
How many peltier module i have to use for removing heat load of 250 watt? Answered
 i am using peltier modules  12706   ( vmax  15 v, Imax  6 A)               by checking it was running at   12 v  and 3.5 A
and   peltier module 12715  ( Vmax  15V ,  I max  15 A )           was  running at  12 v  and 5.5 A
I am using computer SMPS to run this peltiers so i can only get 12 v max
is there any way to increase voltage to 15 volt.
YogeshK33
YogeshK33
4 years ago
i am using total 8 peltier module
4 module running at 12v at 5.5a == 264w
4 module running at 12v at 3,5 a == 164 w
total = 428 w considering cop 0.5 it will transfer 214 w i think so.
correct me if i am wrong..
steveastrouk
steveastrouk
Answer 4 years ago
Where are you transferring the heat ? A 100W module, which might handle a 50 Deg delta T will only move 50W, with a delta T of 25 degrees. It can create a 50 deg delta T, with NO heat flow, or it can create a 100W heatflow with no deltaT
verence
verence
4 years ago
A peltier module doesn't remove heat, it transports it from one side to the other - while generating even more heat! You have to find a way to get rid of all this combined heat on the hot side of the module.
Rahul - S
Rahul - S
4 years ago
Hello Yogesh,
First of all 15V is Vmax. That doesn't mean that you need to supply 15V. 12V is also sufficient.
Now to calculate no. of modules-
Datasheet for 12706
http://www.thermonamic.com/TEC1-12706-English.PDF
Datasheet for 12715
http://www.thermonamic.com/TEC1-12715-English.PDF
These datasheets I found on google. To calculate heat transfer per module.
Consider Voltage applied, Current supplied, Temperature difference and using graphs in the datasheets, you can get watt per module.
[ 250 / watt heat removed per module ] will give you no. of modules required.
(In datasheet it is written Qc / W , that means Qc = heat flow and W = watt ie. unit) because i too confused first time.
steveastrouk
steveastrouk
4 years ago
Don't forget, you trade off power handling for temperature difference.
