89Views6Replies
Author Options:
How might one put a larger pipe where a small is? Answered
I have a mazda protege and my buddy has a old pipe that was kicking around put its quite a bit larger how might I go about hooking that bad boy up?
frollard
9 years ago
Since you're not changing *assuming the exhaust* the full exhaust, there is no benefit other than aesthetics to putting an exhaust TIP on - a larger pipe that clamps onto the existing pipe.
Replacement exhaust tips tend to come with clamps so you just slip the new one on, then screw it down with 3 screw clamps.
CrawdadManfrollard
Answer 9 years ago
its not just a tip its an like 2 feet long
lemonie
9 years ago
A tailpipe?
Larger to smaller diameter?
Cutting and welding is one idea, "filler" is another. I think a cut & weld contraction may be your best professional option. That is like reverse flared-trousers, where you cut slim triangles out and weld-up.
L
CrawdadManlemonie
Answer 9 years ago
Well I have no welding experience and I am looking to do this for little to no cost. What is the filler option?
lemonieCrawdadMan
Answer 9 years ago
You can get "exhaust repair" kits, some kind of bandage and heat-resistant paste / cement. Easy to work with, but not designed to last that long. If a shop sells wiper blades, body-filler, brake fluid etc they'll probably have some. L
