5146Views4Replies
Author Options:
How much voltage and current used in Arc welding? Answered
How much minimum  voltage and current is required to make arc welding?
cerberustugowar
cerberustugowar
3 years ago
I googled "minimum voltage required for arc welding" and this answer came up.
Arc welding involves open circuit (when not welding) voltages which are typically from as low as 20 volts to as high as 100 volts.
I found an instruction manual for a stick welder and it looks to go as low as 30ADC.
I believe there are to many variables to give you a better answer.
Downunder35m
Downunder35m
Answer 3 years ago
Well I measured one during operation and the voltage dropped down to under 15V...
Downunder35m
Downunder35m
3 years ago
Depends on the material you want to weld and of course the thickness of the wire / weldin rods.
