1626Views6Replies
Author Options:
How often should the serpentine belt be changed on a 2004 Ford Explorer V-6? Answered
Re-design
Re-design
10 years ago
Slightly more often than it breaks.
vince 09
vince 09
Answer 10 years ago
 beat answer here lol
automd
automd
10 years ago
The life of a serpentine belt depends on several factors like mileage, load, tension as well as the heat. So you will know if the belt needs replacement if you hear squealing, severe cracking on the underside of the belt, and an angry-sounding alternator.
MahavishnuMan
MahavishnuMan
10 years ago
As mentioned below, look for cracks, chips, and cuts.  Also, inspect the inside of the belt (with the ridges) by feeling the rubber; if it feels hard and brittle, it needs replaced.  Uneven wear on either side of the belt is a possible sign that the tensioner or another pulley may need replaced as well.
seandogue
seandogue
10 years ago
Serpentine belts should last between five and ten years. In my opinion, if it's showing cracks in the outer casing (the flat part), you really ought to consider purchasing a new one and installing it, or having a new belt installed.
NachoMahma
NachoMahma
10 years ago
.  Should tell you in the owner's manual, but the best way to tell is by inspecting the belt. If it has any cracks, chips, cuts, &c - replace it. For more info, try Googling "serpentine belt inspection" (w/o the quotes).
