86Views2Replies
Author Options:
How should I regulate the power for my motors? Answered
Hello, I am planning on building a stepper motor driver using Tom McWire's design. I want to control 3 motors which are rated for 7 volts, 350mA, and 20 ohms. I plan on using a 12 volt 5amp power supply. I am trying to figure out what kind of resistor I should use so that I do not fry my motors. Maybe I am missing something, but this is the way I am looking at it.... If the motor is using 7 volts and the power supply is 12 volts, that means i have 5 volts left to use. 5v over .35amps (the amount the motor uses) is 15ohms. (14.28 rounded up) That also means it uses 1.75 watts (5*.35). Would a 15ohm 2 Watt resistor be sufficient or am I looking at this all wrong? Thank you for your help in advance, folks :-D
lemonie
lemonie
12 years ago
You'd be better with a 7V supply. The resistance / impedance of motors is variable, and you don't really want to be dumping a lot of power as heat.
Power Supply Instructables
L
TheLostAmish
TheLostAmish
12 years ago
lol. I really hope I'm right, cause I just bought all the parts for it
