66Views1Replies
How to Adjust the CO2 laser Speed/Power and Distance in VS. material and thickness
Good day everybody,
You guys have any instructions/ Charts/ Tables to adjust my CO2 laser power, speed and distance away from the work-piece in accordance of every different material (i.e. Acrylic, Wood) and the thickness of each material (i.e. 3mm thickness of wood, 5mm thickness of wood)?
Also, if you could write an example on how to use the instructions, charts or tables, I would really appreciate it,
Thank you everybody in advance,
Regards,
Yousef,
2 years ago
This is very useful
https://www.instructables.com/id/Test-your-materia...
TL:DR Do your own tests, and record the results. A lot depends on your laser tube, and its current temperature and age.
2 years ago
Found solution?
