1737Views12Replies
Author Options:
How to Make a RGB LED Mood without Microcontrollers (with 3 led, 3 potentiometers ) I would like a schematic circuit? Answered
AndyGadget
AndyGadget
Best Answer 9 years ago
To get the maximum range of brightness, work out what value resistor you'd need for each colour LED from the voltage drop (Vf) and maximum current (Ifmax) - There's a calculator HERE.  You'll also need to enter the supply voltage you're running from.  You need the resistors in the circuit to limit the current in the minimum pot position and prevent damage to the LED.
Use 250R (or 500R) pots and connect the centre pin to one of the end pins.  Now wire the relevant LED and resistor to this so you've got the pot, the resistor and the LED in series.  Do this for the other 2 LEDs and then wire each of these circuits across the supply.
You can now adjust each LED over the full range of brightness without fear of damaging it.
Avadhut.Deshmukh
Avadhut.Deshmukh
Answer 9 years ago
3 LED Generating Variable Voltage with a 3 Potentiometer ?
AndyGadget
AndyGadget
Answer 9 years ago
Yes, and 3 resistors to protect the LEDs from burning out.
(Although it's more variable current than variable voltage.)
Avadhut.Deshmukh
Avadhut.Deshmukh
Answer 9 years ago
Please Help me ,Send me circuit ?
AndyGadget
AndyGadget
Answer 9 years ago
All the information you need is in my answer :-
Look at the specification of the LEDs you're using.  The red one will be something like Vf = 1.8V,  If = 20mA.  Put these numbers into the calculator I've linked along with your supply voltage and it will come up with the value for the resistor (for example 180R if you're using a 5V supply).
The circuit for each LED will be exactly the same as the calculator shows you, except you'll also put in a potentiometer in the circuit as well, like THIS.
What voltage are you going to be running it from?
frollard
frollard
Answer 9 years ago
I'm really glad you answered this, because I would have broken the 'be nice' policy telling him/her to search in less friendly terms.
steveastrouk
steveastrouk
Answer 9 years ago
Non-native speaker, cut him a bit of slack.
AndyGadget
AndyGadget
Answer 9 years ago
I was saving him finding the usual arrangement which wires a 10k pot or similar to the led so you get nothing, nothing, nothing, sizzle!
steveastrouk
steveastrouk
9 years ago
Andy's answer only holds for very small LEDs and not the modern high brightness ones, be careful.
steveastrouk
steveastrouk
9 years ago
Use this circuit, and make three of them, right now.
