1622Views10Replies
Author Options:
How to add a op amp to this circuit? Answered
I built this circuit a while ago but the only problem i have with it is that i have to use electronics like my iPod, laptop, or anything with a high volume output. So I started reading about op amps and hwo they "jack up the signal" and I stated wondering could I somehow integrate it into my circuit so that my audio input is higher therefore allowing me to use my cellphone, tablet, and e.t.c? Currently I have a LM324 Quad amp i know fr sure i wont need all those pin. I also have a tip31 and 2N3904 transistors.
iceng
iceng
7 years ago
Try this high gain Darlington configuration before you tackle op-amps
steveastrouk
steveastrouk
Answer 7 years ago
That's what I said....he can use both his existing transistors.
iceng
iceng
Answer 7 years ago
Yes you did.
Since he was already using my first drawing, I had to give him was the second :-)
steveastrouk
steveastrouk
Answer 7 years ago
What are you using for schematic generation for Ibles ?
iceng
iceng
Answer 7 years ago
Iv gotten really good at using the very simple windows paint plus every image is stored in a like subject file.
tramont
tramont
7 years ago
I used a 2N3904 for one led box I made and a tip31 for the other. I thought since the HFE was higher on the 2N3904 it wouldn't require such a high audio signal output but I guess I was wrong.
steveastrouk
steveastrouk
Answer 7 years ago
Wire BOTH transistors into a Darlington connection. Put the TIP 31 to the LEDs, and the 3904 on the input stage. Now your gains MULTIPLY
Like this
http://www.seekic.com/uploadfile/ic-circuit/20097222024525.gif
mpilchfamily
mpilchfamily
7 years ago
Look into a clap circuit. That will show you how to use an op amp to use an audio signal to flash an LED.
tramont
tramont
Answer 7 years ago
Thanks i'll look into it
