372Views1Replies
Author Options:
How to add and power a Bluetooth receiver to battery powered speakers? Answered
I have a iHome speaker that is powered off 4 AAA batteries. I want to add this bluetooth receiver to the speaker.
The bluetooth receiver is powered off USB, but I want to keep the system battery powered.  Can I take apart the bluetooth receiver and solder the power connections to the power connections on the speaker?
The speaker is powered off 4 AAA batteries, so 6 volts.  (How many amps??)
The bluetooth is powered from USB which is 5 volts, correct?
Would the 6 volts from the AAA batteries damage the bluetooth receiver?  What about current?
mpilchfamily
mpilchfamily
Best Answer 6 years ago
The voltage tolerance of the receiver may be able to handle the 6V. But you can always by a 1N4001 diode and solder that between the receiver and the power source. The diode has a 1V voltage drop so the receiver would only get 5V from the power source.
steveastrouk
steveastrouk
6 years ago
The current will look after itself. Use Mpilch's diode and you shouldn't have a problem.
