704Views6Replies
Author Options:
How to add more brightness to my current LED circuit? Answered
Hi everyone,
Which component should i use to boost up the brightness of my circuit. I'm using this my circuit as my "moon light" for my silver arowana.
My circuit. I'm actually used the help ledcalc.com/#calc for my circuit.
The power source for my circuit is 12v adapter ,500 mA, 50 hz and 13 VA
(note, i don't want to change to a super bright led, preferred using my current led)
Thank you.
rickharris
rickharris
Best Answer 9 years ago
Short of passing more current though the LED - They have limits!
You could try putting some aluminium foil behind the LED as a reflector.
Other wise buying a higher current LED is the only way my friends are wise
steveastrouk
steveastrouk
9 years ago
You're stuck, unless you add different LEDs. You MIGHT increase the current to 30 mA, but without a datasheet for your LED, you may ruin something.
Steve
yraj1
yraj1
Answer 9 years ago
thanks for replying Mr Steveastrouk,
orksecurity
orksecurity
Answer 9 years ago
+1. Unless the LED can tolerate more current, what it gives you is what it gives you. More LEDs or brighter LEDs is the right answer.
appolo
appolo
9 years ago
For most standard Led's 20Ma is around the safe operating limit, so the answers already given hold true. If you go beyond this point the device dissipates more power in the Led and heating causes failure. However you can experiment with higher current and pulsing them at a higher frequency . By switching them off and on rapidly known as PWM... reduces the heating effect and may give you the results you are seeking!! I have Led circuits using this technique but it's purely trial and error, otherwise high brightness Led's are the answer.
yraj1
yraj1
Answer 9 years ago
thanks a lot.. that a abundant of info you got their :)
