87Views0Replies
Author Options:
How to alter the code in this LED chase Answered
Hi,here is the code i have for a chase controlled by a button. When the button is engaged (held in) the chase runs. When the button is released the chase stops. My question is how can I make the LEDS appear to go haywire when the button is released and not simply go off.
// A chase controlled by a button
int Button=2; //button assigned to pin 2
int timer = 150; // The higher the number, the slower the timing.
int ledPins[] = {
3,4,5,6,7,8,9,10 }; // an array of pin numbers to which LEDs are attached
int pinCount = 8; // the number of pins (i.e. the length of the array)
void setup() {
Serial.begin(9600);
pinMode(Button, INPUT);
int thisPin;
// the array elements are numbered from 0 to (pinCount - 1).
// use a for loop to initialize each pin as an output:
for (int thisPin = 0; thisPin < pinCount; thisPin++) {
pinMode(ledPins[thisPin], OUTPUT);
//turn LEDS on
void loop() {
while (digitalRead(Button)==HIGH);
//delay (10);
Serial.println("LOW");
while (digitalRead(Button)==LOW)
Serial.println("HIGH");
//turn leds on
digitalWrite(ledPins[thisPin], HIGH);
delay(timer);
//turn leds off
digitalWrite(ledPins[thisPin], LOW);
//turn leds on
for (int thisPin = pinCount -1; thisPin >= 0; thisPin--) {
//turn leds off
delay(timer);
many thanks,
Frank
